4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#1043020 07/16/2014 8:48 PM
I need to figure out a pedal setup for my '50 3100. I have a T5 behind a 235. I have no pedals at all right now, just the engine and tranny on the frame.
I do have the original pedal assembly. I need power brakes and a hydraulic clutch but am totally lost on how to get a hydro clutch setup with the stock pedal assembly or how to get a slave on the 216 bellhousing.
Help?
jrdamien #1043082 07/17/2014 3:05 AM
The original mechanical clutch linkage will work fine with the T5, no need to convert to a hydraulic clutch.
Bill Burmeister
jrdamien #1043093 07/17/2014 3:34 AM
jrdamien,
Art Morrison has a nice looking hydraulic clutch/power brake setup. I don't know if this link will work or not but on page 16 there's a picture of what it looks like and it says they make this kit for stock frames:
http://www.artmorrison.com/2006cat/2014catalog.pdf
This hydraulic slave cylinder might be able to be modified to work on your I6 bell housing. You can contact them and see if it would work.
http://www.novak-adapt.com/catalog/clutch/kit_hcrc.htm
I actually saw the linkage up close on someone else's frame today. Yes, that will work perfect - as simple as simple gets. Just have to rig a way to get a booster on that assembly.
