2 members (Otto Skorzeny, 1955 1 Series), 89 guests, and 4 robots.
Topics128,031
Posts1,055,436
Members48,422
#1043532 07/19/2014 2:28 PM
Those of you who visit the VCCA forum will find that I have posted this topic on that board as well.
I went out yesterday morning to start the truck ('53 3100 1/2 ton truck) and the battery, a new 6 volt AGM, was dead; the VOM showed 0.75 volts. With all wires disconnected from my 6-volt Delco generator I get the following readings:
From Field terminal to ground 0.2 ohm
From Armature terminal to ground 1.5 ohm
My best guess is that the cutout in the voltage regulator stayed closed and back-fed power from the battery to the generator, maybe leading to a short inside the generator. Am I right on this? I imagine the voltage regulator is not repairable. Have I fried my new battery and/or my generator? Any help greatly appreciated.
1953 Chevrolet 3104 1/2-Ton
More pix
Making resistance readings on a generator is pointless- - - -it will always read close to a dead short, good or bad. That's why there's a cutout relay. Take the generator to a rebuilding shop where they know how to check it out, NOT a big box place like Auto Zone. It will need to be dismantled and checked on some special equipment, including a growler.
Recharge the battery over several days at a low amperage (10-15 amps) until the specific gravity of the electrolyte is 1.265 or above on all the cells- - - -it will probably be OK.
Thanks Jerry, I'll pull the generator and get it tested on Monday. Good to know the resistance readings don't necessarily indicate a problem. I've got the battery on a slow charge (about 1 amp - it's the only AGM charger I have for 6-volts) so it should be back to charge by Labor Day.
More pix
I have charged 6 volt batteries with a 12 volt charger by wiring a sealed beam headlight bulb in series with the battery to limit the voltage applied to the battery by the charger. Works well!
There is a procedure for charging AGM batteries on the Optima website. The headlight trick may work well on a lead acid battery but I wouldn't try it on an AGM.
