| | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | Any place to buy the exhaust pipe for a 1941 2-1/2" pipe from the manifold to the muffler. with the 3 bolt flange .. thanks
I like fixing stuff.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | The original pipe is approximately 2 inches in diameter, and the exhaust manifold has two studs. From your information, I would infer you are asking how to get a pipe for a modified vehicle. Best to find a shop that will bend pipes to fit your application. | | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | It's 3 stud and 2-1/2" inch It's a CC-300 GMC 1-1/2 ton with a 248 ....... no muffler shop for 200 miles. this is the OEM pipe. NAPA has like 200 exhaust pipes hanging like Christmas tree ornaments and sound like wind charms. I would just like to find someone that makes one for 41-46 GM truck/PU
