2 members (BC59, Uncles51),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,481 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 12 Junior Member | | Junior Member Joined: Feb 2001 Posts: 12 | Hello all, I'm working on restoring a 1949 Chevy pickup. I have disassembled the truck and took notes and some pictures!! As I contemplate re- :confused: assembling my truck I noticed that I have (2) rods thats 26 1/2" long and shaped like the fender brace rods that I have forgot where they belong. Can you help me with there location? I believe they belong somewhere in the front end.
Thanks Lonnie | | | | | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | Lonnie, if these braces are flattened at one end with two holes to receive bolts and threaded at the other end, they are the diagonal fender braces located in the engine compartment. The flattened ends are connected to the firewall (near the center) with 5/16"-18 x 5/8" cap screws into captured hex nuts. At the fender ends, the threaded rods are connected to v-shaped brackets using 3/8"-16 hex nuts and washers (see pic below) [img] http://www.laroke.com/larryk4674/2002/bb122202bt.jpg[/img] | | | | | Joined: Feb 2001 Posts: 12 Junior Member | | Junior Member Joined: Feb 2001 Posts: 12 | Thanks Larry, but the rods are flat on both ends. They look exactly like the fender brace rods but longer. Same angle of the ends as the fender brace rods. Lonnie | | | | | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | Ahh! Clears things up for me. 54-55 1st series do not have those braces. | | | | | Joined: Feb 2001 Posts: 12 Junior Member | | Junior Member Joined: Feb 2001 Posts: 12 | Thanks Chuckthetruck!!! Lonnie | | |
