| | | Forums66 Topics128,154 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | What is the difference in gearing between my original 3 speed tranny in my 50 3100 and a later model 3 speed with overdrive? Like a 58 3 speed with od? Would it be like a 4 speed with a 4th gear being overdrive? how much increase in highway speed do you get with this overdrive? Does a 58 3 speed with od use a torque tube set up or standard open driveshaft configuration? Just trying yo gain some knowledge. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Heres some good reading on the OD unit. Dave | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | While your 50 3 speed trans may have similar gear ratios, little else is the same as the 58 OD transmission. 55 up vehicles do not use a torque tube, all are open driveline. The BW OD replaces the tail shaft on a standard 3 speed transmission. It has an electric solenoid, other electrical components, and a cable to engage the system. There are some later 4 speed transmissions that 4th gear is an overdrive. They are completely different from the BW unit. This and most OD units are 70% overdrive. They will lower engine rpm's and can increase speed accordingly. You should consider that early vehicles were designed to drive at lower speeds and the brakes and steering were designed accordingly. Fred
