| | | Forums66 Topics128,036 Posts1,055,452 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | I need to figure out a pedal setup for my '50 3100. I have a T5 behind a 235. I have no pedals at all right now, just the engine and tranny on the frame.
I do have the original pedal assembly. I need power brakes and a hydraulic clutch but am totally lost on how to get a hydro clutch setup with the stock pedal assembly or how to get a slave on the 216 bellhousing.
Help? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The original mechanical clutch linkage will work fine with the T5, no need to convert to a hydraulic clutch.
Bill Burmeister | | | | | Joined: Jan 2013 Posts: 3 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 3 | jrdamien, Art Morrison has a nice looking hydraulic clutch/power brake setup. I don't know if this link will work or not but on page 16 there's a picture of what it looks like and it says they make this kit for stock frames: http://www.artmorrison.com/2006cat/2014catalog.pdf This hydraulic slave cylinder might be able to be modified to work on your I6 bell housing. You can contact them and see if it would work. http://www.novak-adapt.com/catalog/clutch/kit_hcrc.htm | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | The original mechanical clutch linkage will work fine with the T5, no need to convert to a hydraulic clutch. I actually saw the linkage up close on someone else's frame today. Yes, that will work perfect - as simple as simple gets. Just have to rig a way to get a booster on that assembly. | | |
