| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | Henry is back on the road with his new SBC.....now it is time to freshen up that suspension.
My old leaf springs are sacked out and shot.
What is the best (Cheapest??) source for replacement springs, shackles, etc?
1949 Chevy 3600 | | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | Eaton Springs Or you can look into putting in a 4 link from $390 weld everything up yourself to over a thousand for a custom build weld it in only setup. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | St. Louis Spring also makes a good spring for a good price. Samantha | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | St. Louis Spring also makes a good spring for a good price. Samantha | | |
