| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | My '55.1 has 16" 6 lug wheels 4,1/2" wide , I've located 4 , 15" came off a 55.2 Chevy pick-up . 6 5.5 and 8" wide . will this swap work ? Do any of u see any problems . Thanks ....
" STUCK IN THE '50'S "
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Don't know the answer to your question, but the changed diameter will affect your speedometer accuracy if that's important to you. Take onboard a GPS device, calculate the % of change and get together with a speedometer service to get your speedometer accurate again.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Just check the back space , but I think the trucks are the same.
I had 15" originally on my '40 and put 16" x 7" on recently , Just made the back space the same and no issues. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If they cleared fine on the '55 2nd that they came from, they'll work fine on the '55 1rst.
Bill Burmeister | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Went to Houston and picked up the wheels, American Eagle Alloy 15" series 218, back space 4", the tires he had on the rims when it was on his 55.2 were p225/75r/15 . I got under his 55.2 and checked out the 55.2 tie-rod end . every thing looked just like my 55.1 . So I'm sure they will be ok . my orig. back space is 3.5" .... I wanted to use my original rims but they still had tubes in them , even with air in them they had rusted v. badly around the air stems , even to the point they would have to b welded and drilled out on the opposite side . then power coated at $45 ea. these rims was only $250,....
I want to thank u guys for all the help ....
