| | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I'm working on my rear brakes but am missing the parts that connect the parking brakes.
Any idea where I could find them? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Check here to see if your part is listed: Emergency brake parts Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2014 Posts: 120 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 120 | Are you talking about the round bar that has a slot at one end and the other end has a bend and a cotter pin? I had one that was missing from my truck and could not find one so I got round bar from lowes and bent and welded and grinded one to match what I had on the other side. I will try to get a pic of it off my phone to post for you so you can see what it looks like. Skip EDIT here is a link to an exploded view and part number 3 is what I had to make along with fabbing a spring number 4. http://chevy.oldcarmanualproject.com/military/1942/42cm4x2t0506.htm
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I was looking for the parking brake lever. I have the rods. Btw, thanks for the link to the exploded view. I wasn't sure what the parts were called. | | |
