| | | Forums66 Topics128,162 Posts1,056,916 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Hello all! I have removed the doorpanels and I have noticed some rust on the inside of the panel with some white stuff around it. Not sure what it is. Will get a pic and post it. Any ideas on how to remove this?
Thanks | | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | | | | | | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | I read in the book "How to Restore your Chevrolet Pickup", that the best way to handle rust on the inner door surfaces is to use a rust neutralizing product. It says that products like Zintex from T.N. Cowan, converts rust to an inert coating that seals the metal against further rusting. The book goes on to describe that the metal must first be clean of grease and paint and if possible, loosen any rust scale with a wire brush. It says that the best way to use it on the inside of a door is to take the door off the truck and lay it down with the outside skin facing down. Next you poor the rust converter inside the door and then the pick the door up to spread it around by tilting it at different angles. Once you have done this the instuctions call for washing the metal and then sealing it with a coat of paint. The best way to prime the area is by using the same method used to apply the neutralizer. Then just let it dry and repeat with a finish coat. Of course you should read the directions with the product but I think I got everything in here that the book said. By the way this book is an excellent book with lots of little tricks like this. I really like it as I am just starting into my first project. The title again is "How to Restore Your Chevrolet Pickup", and it is by Tom Brownell. I hope this helps! | | | | | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | Rust needs to breath, cut of the source and it stops.So after the treatment what ever it may be,seal it from the moisture and air with some quality stuff and it will be here for your grandkids. O | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would fill the door panel with POR15 or Zerorust using the pour it in and slosh it method, and not worry about it. Any multistep process is going to be a pain.
