4 members (Steelonsteel, Rich'sToys, Brian Moore, klhansen), 81 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#1041664 07/11/2014 1:07 PM
Last week I bought a torque multiplying wrench. It looks like a socket drive on steroids, long heavy handle and a very large business end. On top is a female 1/2" socket and on the bottom is a 3/4" male drive. Inside the head is a 1:9 gear reduction. So to use it one would position the handle so it is blocked, put a socket on the 3/4" side and a wrench or torque wrench on the 1/2" side. You get 9 times the torque out of the output. I have never seen them for sale before.
1951 1 Ton Completed
It's basically a small gearbox, think of it as a one ratio torquing transmission thumbs_up
But Fred, now you won't get the exercise we older guys need.
Denny G
Denny G
Sandwich, IL
They have been commonly used on large fasteners in industrial applications, such as pipeline, refineries, etc. Now they sell them for RV and truck use instead of the old lug wrench and breaker/beater bar set-up.
I wish I had had it when I was taking off the pinion nut!
Denny, now I have to look for another monster nut to undo.
They come in bigger sizes. I have a few at the shop.
I have a JH Williams with up to 250 ft. lbs input and 1,000 ft. lbs output. We don't use it much, but there are times when things are too close for an impact and it is good in the field if no air is available.
This is new to me!
Not sure I would want one though, unless I were working on really Heavy Equipment.
Moderated by  MNSmith
