| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've got a bunch of 1/4" wall 4x4" square tubing, an upper wheel, a set of rollers. So I've got the major portion of an English wheel. I know how I want to design a floor model roll about frame. Now all I need are some ideas for the lower tube, lower yoke, kick wheel adjuster and a quick release setup. Anybody got one of them in their shop or have access to one that they can shoot some pictures of or make a drawing of or have plans of or just take some measurements of that lower tube????
Denny Graham Room for one more tool, in Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Denny; I "subscribe" to Homemade Tools. Here are a few examples of English Wheels. Might give you some ideas. Homemade English Wheels SimS | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | tks Sim, got a little more about the quick release. Think I can figure that out. Need to know more about the adjuster and how it is machined. I've been thinking about an acme threaded rod and nut in the bottom of the tube. Just let it push against a keyed stem on the yoke. Having been around welding fabrication and machine work all my life, I have some real concerns about alignment of the two wheels after it's all welded together. Leveling the lower roller is clear enough but keeping both wheels tracking in the same line concerns me. I think it would be a good idea to make the yoke for the upper wheel a bolt on part so it could be aligned with the lower roller and shimmed if need be.
Been lookin' at John Glover's wheel as a pattern for a frame. It's simple, has a large capacity and is rigidly braced, that's the key word here, 'rigidly braced. That's the biggest problem with home made or cheap (HF) English wheels, they really need to be immovable to function properly. Keeping the upper and lower legs perfectly parallel would be the challenge. Don't have any idea how you would pull 1/4" wall 4x4 tube back in alignment once it was welded. I suppose you could run some blind weld along the side you needed to pull in but I'd rather not do it that way. One could always weld some sort of attachment to the side that need tweaking, that would pull it in some depending on the size of the bead and it would look like it was planned that way. Denny Graham Just one more tool takin' up space, in Sandwich, IL
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Denny, typically if you alternate from one side to the other you can keep the forces equal that the frame shouldn't pull that much. If it does move on you, some torch "contraction" will pull things back in line.... http://www.metalwebnews.com/howto/contraction/contraction.html | | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Hey Denny, if I start mowing your lawn for the next 27.9 years, will you put me in your will?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Robert, I'm somewhat familiar with welding. Learned the trade from me pop when I was just a sprout. Made my living at it for most of my adult life between running the family's welding fabrication shop when younger then working at a government accelerator as an instrument welder for many years toward the end. That's exactly why I'm concerned about the alignment. With that large of a weldment it's orful easy to get a slight misalignment of the two legs. Gonna have to make sure I've got adequate adjustment designed in to the anvil mounts for the tracking after the frame is welded. You know that, no matter how much care and technique you put into it, it's still gonna warp some. Only way to combat locked up weld stress is to weld it in a jig then stress relieve it by heat treating it. But that of course is impractical for a large structure.
Gonna need someone to leave everything to Carl. All the one and only daughter is interested in is politics and shoes, as is her significant other. They're no doubt gonna have a grand two day auction the weekend after I'm gone, then head for a warmer climate.
I'm starting to zero in on a design for the quick release cam. Think a lower tube from telescoping square tubing might be the best choice. I did find, on my shelf, a handful of 3/4" acme threaded rod, so I've also got the up down adjustment somewhat figured out.
I guess it's about time to stop the train and get the power over to my mill. Been putting off running the power to the other end of the building for my machine tools because I know it's gonna tie me up for a week or two. First I have to finish insulating a 12 foot wall then sheeting it with steel before I can run the electric, it's going on the outside of the sheeting. Kind of a domino effect goin' on here at the new homestead. Can't do this till that's done and can't do that till this is done and on and on. Better get to work, sun's gonna be up soon and I'll have to crawl back into the coffin. Denny Graham night stalkin' in Sandwich, IL
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | If you look at some of the parts made by Joe Andrews of Hoosier Profiles, they are about the finest wheeling components around. He does have the quick release made into the upper wheel cradle, and has a real nice upper adjuster. May give you some ideas. http://hoosierprofiles.com/Adjusters___Lifters.html The parts I used on the wheel I made were from used MetalAce components bought off Craigslist, a bad economy and the closing of a motorcycle shop, he didn't have the storage for the complete wheel and cut off the major components. Hindsight I should have bought all new parts from Joe, I would have a much nicer machine. My adjuster had already been welded in once, so after the second installation the outer tube had shrunk quite a bit from the heat where the Acme screw didn't perform as well as one would expect. The Hoosier Profiles adjuster that I used to replace it was comparatively like a fine clock mechanism. Here's a link to my build thread, frame was based on the Imperial Wheeling Machine by Kerry Pinkerton. There are plans on allmetalshaping. This design uses a bolt on lower arm to give you a bit of fudge factor in alignment of the top to bottom, and the ability to change lower arms in the event of clearance issues on high crown panels. Not sure how adaptable that is to the Glover design, but may give you some ideas. The adjuster being on the top or a kick adjuster on the bottom is really a personal preference, I thought with wheeling larger panels in the machine that the upper adjuster may be more accessible. http://www.metalmeet.com/forum/showthread.php?t=6763 Metalmeet, allmetalshaping, and the home-built tools link above, all have quite a variety of designs that you could look at, and the HAMB also has one thread on "show your English Wheel". MetalAce recently posted some details on a new frame design, I believe based on the John Glover, here is their "build" thread.... http://www.allmetalshaping.com/showthread.php?t=11059 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thank Robert, got a busy day and a cruise night tonight but I'll take a look at the links tonight. I've been to a few of them, such as the HAMB, allmetalshaping and Metalmeet. Not happy with the final design yet so I'm open for any new ideas. Thanks for the input.
Denny Graham Sandwich, IL
| | | | | Joined: Sep 2015 Posts: 4 New Guy | | New Guy Joined: Sep 2015 Posts: 4 | Denny; I "subscribe" to Homemade Tools. Here are a few examples of English Wheels. Might give you some ideas. Homemade English Wheels SimS Jon here from HomemadeTools.net. I know this thread is an old one, but thanks for the mention  To celebrate our 20,000th homemade tool, we made a new ebook featuring our top 50 homemade tools. You're welcome to it for free: http://download.homemadetools.net/50MustReadTools.pdf | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Welcome to Stovebolt, Jon; thanks for the link to the book. Check out our swap meet forum...buy you a 'bolt...
You'll need 90% of those tools to fix it up right!
Brad Wrench Fetcher, PhD | | | | | Joined: Sep 2015 Posts: 4 New Guy | | New Guy Joined: Sep 2015 Posts: 4 | Thanks for the warm welcome. Just got to convince my wife that it will just be oooooone more project :cool:
Forgot to mention; we do have a bunch of stovebolter tools listed: http://www.homemadetools.net/sites/stovebolt.com (you can see all tools by site here: http://www.homemadetools.net/sites ) | | | | | Joined: Sep 2015 Posts: 4 New Guy | | New Guy Joined: Sep 2015 Posts: 4 | Hey guys - we have a new ebook out: How to Make a Belt Sander. 100% free of course. Click here to check it out: http://www.homemadetools.net/homemade-belt-sander | | |
