1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 138 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 138 | Can someone offer some advice on how to remove the steering wheel horn button on my 46 1/2 ton? The service manual doesn't have anything and a Google search comes up empty.
Thanks, Dave | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Its right hand threaded. Just unscrew it like a nut. Then there is cup that is held in place by a ring. Just open up the ring and the bottom cast piece will be free of the steering wheel. That last part is by memory is it might not be exact. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Dave, If you still have the original steering wheel and horn set-up, the horn button has a short bolt attached to the inside cap. The cap has to be turned (unscrewed ) to remove. Check this site to see photos. Horn Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2012 Posts: 138 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 138 | Thanks to both of you for the info! I wouldn't have figured that out without breaking something.
Dave | | |
