2 members (Shaffer's1950, 1 invisible),
84
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hi guys
quick question, does stock 3100 have a transmission cross-member?
i have a cross-member under the bell housing but nothing further back.
ive read reports of people having to move or install modified members when fitting power brake master cylinders - but when i looked under my truck theres no member in the way and heaps of space....whats the skinny?
(my truck has a 235 engine stock manual 4 speed) cheers mike
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no cross member under a standard trans, it just hangs off the bellhousing
Bill | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What year is your truck? Up to 1953 there was a transmission cross member. Starting in 1954 with the new angled bellhousing mounts the trans crossmember was dropped.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hmm, maybe its a terminology thing... ive looked through the gmheritage center docs and the frames from 1947 right through to after 54 look the same (regarding transmission crossmember) the frames all have what gm calls an `engine rear support` cross member (see frame 70) http://gmheritagecenter.com/docs/gm...hevrolet-Trucks/1949-Chevrolet-Truck.pdfthe design of this crossmember was changed a little in 1954 to solve some member cracking issues but otherwise the member apears to have always been there.... or am i missing something?? but theres many a post here talking about removing it or not having it so i assume this is to accomodate different engines/transmissions fron stock? ..im just getting more and more confused lol!
| | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | ah, interesting - you make a good point!
thanks, that explains a lot.
so my truck is missing this member (have to say it doesnt surprise me the PO owner from what i see was a real joker) - so when i upgrade to power brakes i may as well buy the matching member
thanks for your help!
cheers mike
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mike,
Many people report that cross member being missing from pre-54 trucks. The best guess as to "why" is that the cross member was removed to more easily remove/install a transmission, and then the cross-member was simply not put back into place?
| | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hi yes thats possibly why its missing but truth be told ive discovered so many horrors on this truck done by PO that nothing would surprise me.
case in point, i just discovered he had taken an angle grinder to the brake drums to grind away the worn lip of the drums and in doing so destroying a lot of the drum surface. ....nothing would surprise me now lol
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Seems like it would be rather obvious if the crossmember had been removed, that is quite a large section and they're riveted into the frame at many points. You say it's titled as a 3100 but are you sure you don't have a 3600 frame???
Denny G
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Denny,
Is there no need for the 3600 and larger trucks having a transmission mount because the engine-mount frame cross-member being shorter and stronger than the one on the pre-1954 3100?
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | The transmission crossmember which the torque tube ball collar support bracket,mount bolts to, is bolted to the frame (not riveted), on a 3100. I am guessing that is why it isn't included in the factory pictures of the frame. If you are running a torque tube rear axle, you need to find a crossmember and the torque tube ball bracket/mount. Carl
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Carl.
I thought they were bolted onto the frame, but I've only worked on 1954 enclosed drive-shafts in the last 30 or so years (no manual-transmission cross-member).
The 1954 Hydra-Matic cross-members are also bolted on (both the rear-engine cross-member and the rear-transmission cross-member).
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | My 1950 3100 has a crossmember ...pic... Bolted to the frame ..in the back ground in this pic... If I had gone with a booster brake kit I would of had to remove that crossmember. | | | | | Joined: Nov 2012 Posts: 16 New Guy | | New Guy Joined: Nov 2012 Posts: 16 | I think this is the member you are talking about. I have a 52, 216 4 speed, this is what I have. http://m.ebay.com/itm/121278080166?nav=SEARCH
1952 Chevy Pickup - 3100 in process resto
| | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | Hi guys, aaahhh i think i worked it out.... the transmission mount attaches/sits under the torque tube flange my truck has no torque tube it has an open drive so im guessing thats why the crossmember is missing so my question now is.....would it be best to fit a crossmember and mod up a support to the tranny casing....i think i should a really nice pic on this excellent gallery. http://www.cardomain.com/ride/1969206/1950-chevrolet-3100/(click `photos`, `load more` then 3rd line of pics down)
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey, my bad guys, I've got two 3600's here but no 3100. Been helpin' a friend out with his 3100 and thought the transmission crossmember was riveted, Just call him to check it out, bolted in just as ya'll say. Should have kept me yap shut since I couldn't head out to the garage and check it out in person.
DG
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have seen so many of these trucks without the crossmember with no ill affect that I believe it is not necessary.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Once the rubber pad in the torque ball support bracket gets mushy from gear oil, this crossmember serves no purpose, except for a little extra lateral support to the frame. I believe that support bracket was designed to take out some of the wiggle out of the torque tube. If you go to an open drive shaft, I wouldn't attach the transmission to the crossmember, as it will likely fight with the front engine mount and the two mounts at the bell housing. Carl
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | . . . I believe that support bracket was designed to take out some of the wiggle out of the torque tube. . . Carl What about the 1954 1/2 ton trucks' torque-tube "wiggle"? Management of weight, not wiggle was what was being dealt with. GM stated for 1954 trucks that the change in design of the frame and rear-motor-mount cross-member allowed for removal of the transmission mount (and cross member). The new rear-motor-mount cross-member was stronger in 1954 and later, allowing it to bear the weight of those parts of the drive train. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Think that larger crossmember in '54 might have just been because the HM was now being offered as an option? Even though the rear of the HM was supported there was still more weight on the rear engine mounts with the HM than with the other options.
As far as I know there never was a problem previously, cantilevering the 150lb SM420 from the bell housing. The whole works, engine and trans being mainly supported by the rear engine mounts, kind of like a teeter tauter favoring the front or engine side.
DG
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | We can speculate and make assumptions based on the information in the 1954 Truck Engineering Features manual (linked-to above).
The 1954 3100 H-M has a significantly different frame set-up compared to standard transmission 3100 trucks. The H-M-equipped 3100s had a set of two bolt-on frame cross-members: one under the rear engine (where the standard cross-member was) and an additional cross-member under the rear of the H-M transmission.
The extra cross-member was needed for the very heavy H-M transmission; and, the two cross-members were bolt-in to allow the transmission to be easily removed from below (with or without the engine).
