5 members (Wheelie, Jay R, 1955 1 Series, Napco Man, WICruiser), 136 guests, and 2 robots.
Topics128,083
Posts1,056,080
Members48,434
#1038395 06/28/2014 3:38 PM
Would someone please explain to me how the replacement oil pressure line fits together? This is for a 216 engine. It doesn't look exactly like the original and I don't want to wreck anything.
It seems like the nut slips over the line, and then a cone shape bushing fits on the very end of the line. Is this correct?
The bushing doesn't want to slide over the line fully, and it seems like it will fall out of position, fall and the floor, or somehow not create a proper seal.
Stove #1038406 06/28/2014 4:23 PM
Can ou post a pic?
Here is a picture from Denny's website of what the original fitting looks like.
http://www.pbase.com/dennygraham/image/137095044/large
you have a separate cone shaped bushing?
Stove #1038466 06/28/2014 10:37 PM
Yeah, the kit came with 1/8" tubing that slides through the firewall, then the nut slides on, and then the bushing slides on.
Upon closer inspection, the bushing was not sliding over the end of the tube because the tube was slightly out of round when it was cut. I will post pics later.
Stove #1040048 07/04/2014 10:04 PM
Here are pics of the replacement line. The existing nut was stripped (by the previous owner) and it would not tighten properly and dripped.
I used a scratch awl to open up the end of the tubing, and a file and some sandpaper to round the ends where it was cut / squeezed / crimped / out-of-round.
Works good now.
http://i128.photobucket.com/albums/p195/BassBucket/52%20GMC/20140628_130728.jpg
http://i128.photobucket.com/albums/p195/BassBucket/52%20GMC/20140628_130809.jpg
Stove #1040053 07/04/2014 11:06 PM
You are talking about the oil line for the oil pressure gauge??
