| | | Forums66 Topics128,053 Posts1,055,776 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | I've put about 1500 miles on my 46 C O E over the last 5 years or so and I've developed a grease leak on the bottom of the steering box. It's coming out the bottom bearing ajustment thread at the bottom of the lock nut. The grease is coming out around the threads. The gear box is good and tight and so is the lock nut. I don't want to disassemble the box. Is this normal? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You might want to put John Deere corn head grease in it, see if you can get the old stuff out. I had a drip on my '40 and I put corn head grease in and no more problems. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Yup, like Don says, corn head works like magic. My steering box leaked like a sieve. Whatever you poured in the top (including STP) ran out the bottom onto the driveway. corn head stays put, and its extra slippery too. | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I put proper steering box lube in mine. Like corn head grease its about 600 weight oil, it flows like treacle. After 6 months it started coming out through the thread ofvthe lower adjusting nut. Without too much hassle I unbolted the steering box enough to lift it up a bit, remove the lower adjustment nut and screw, drain the oil (leave it for a week dripping in to a container). Then I wound PTFE plumbing tape around the thread with a skim of RTV around the nut face. Reassembled it and all good now.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | anyold iron,
What brand steering box lube did you use? Penrite's lube is supposedly equivalent to 1200w oil.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | anyoldiron,
