9 members (Bill Hanlon, Jon G, Ponchogl, dt235sd, rfs56trk, Steelonsteel, Maybellene, 49choptop, 1 invisible),
120
Mod | | | Forums66 Topics128,096 Posts1,056,478 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | My 51 3100 has a rebuilt 59 235 in it. The motor is clean inside (no built up crud).When I got it I drained the crankcase and put in off the shelf brand name 10-30w oil. Now that I have a few hours on it and am installing an oil filter I want to change the oil.I plan on changing it often. My question is,is there any reason not to use good quality 10-30w motor oil in my motor? If there is, what would you recommend? Growing up I was taught to use non-detergent 30w oil in an old motor but this motor has been rebuilt and most likely cleaned so I'm assuming that basic motor oil is proper. Thanks---Jack | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jack,
You might have opened a can of worms.
In the late 60s, I was also told to use non-detergent oil in a 216 and a high-pressure 235. However, by the time the high-pressure 235s were introduced (1953/54), GM was recommending detergent multi-grade oil.
GM was also recommending detergent oils in earlier years, for hard-working engines.
Your 10-30w (10-30, 10W-30) oil is OK.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Agree, A good brand of 10/30 will be excellent in that engine. When you get that oil filter on it you won't be able to see the oil on the stick as it will be so clean. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Detergent oil was available in the early 40's. In 1942 the US Military had almost universally switched to it and requiring filters on almost all motor vehicle engines.
A good 20W or 30W oil is all you need.
I would run a 20W oil over a 30W. Your main concern is engine start up and cold viscosity.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | My question is, is there any reason not to use good quality 10-30w motor oil in my motor? There is no reason not to use a good quality 10-30w oil in your motor (or, any other modern multi-grade oil). | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | "20W" is not 20 weight... | | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | I ran 10W-30 in my rebuilt high oil pressure 235 with hydraulic lifters. I had one lifter that would clack until it reached operating temperature. I switched to 5W-30 and the lifter started to act right at all times thereafter.
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | "20W" is not 20 weight... But that's how it appears in the manual You always want to run the lightest weight oil you can because the oil does not reach its listed viscosity when cold. 30 weight (or ever 30W) oil much more viscous 'cold' then when at operating temp... and the few minutes its takes to get to operating temp is when all the wear takes place. You will see lower gauge pressure with the lower viscosity oil on worn engines and using 30 weight or even 40 weight oil is not a fix, just a crutch to make the oil gauge 'look right'. So it is 'wrong' to use 30 weight oil? No. Given the choice 20W or even straight 20 weight oil is preferred.
| | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | And when we ran straight weight oils, we changed them summer and winter. Now we use multigrades, and only change them when needed. I'd give it a go with the 10W30. A light 20W may thin out too much in hot weather. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I"ll bite Winter? Or Weather? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | It's winter in the southern hemisphere right now. Carl
| | | | | Joined: Dec 2008 Posts: 59 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 59 | A name brand 10W-30 is all you need and you should be fine.
"One thing about trains, it doesn't matter where the're going, what matters is, deciding to get on." - Polar Express
