4 members (jmoore, Jon G, 51sub, 1 invisible),
104
Mod | | | Forums66 Topics128,288 Posts1,058,574 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10386 05/04/2002 9:54 PM | Joined: Apr 2002 Posts: 1 Junior Member | | Junior Member Joined: Apr 2002 Posts: 1 | I have a 1946 chevy 1/2 ton I am trying to restore. When I got it the previous owner had already put a 235 engine in it. The block says it a 1956 when I look up the #'s. The tranny is bad and I would like to replace tranny and rear end with something capapble of highway speeds. The only concern I have is that I don't really want to have to modify the floorboards and such from a larger tranny if I don't have to. Any suggestions? Chris | | |
#10387 05/05/2002 3:37 PM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | There are a lot of ways to go with this. This is what I did with my 46. I wanted to upgrade the drive train with the idea in the back of my mind to some day drop in a V-8. I have a 55 235. First I found a 56 1/2 ton rear end with 3:56 gears. The center pumpkin will fit right in the 46-54 housing. This way I am using my existing brakes and shocks. I had to weld new spring saddles to the housing because the existing ones were the type thet rotated. Next I found a 53 bellhousing that had the right bolt pattern for the later trans (they changed in late 47) I had to build a mounting bracket that mounts to the new bellhousing to mount the master cyl.and clutch pedal to. Next I used an sm420 4 speed from a 65 1/2 ton this is an open drive line unit. It has a granny low. Next I found a drive line out of a 77 1/2 ton and it was just the right length. NAPA makes a u-joint with two differens sizes that worked perfect to hook it up.. This is just one option. , Rick  | | |
#10388 05/06/2002 6:24 PM | Joined: Jan 2001 Posts: 30 Member | | Member Joined: Jan 2001 Posts: 30 | Don Epps used a t5 and it looks like it fits well and you don't have to relocate the pedals. First thing- have you checked your bolt pattern on bellhousing. A pre 48 bellhousing won't do but a later one will have a pattern which allows you to bolt in almost any trans you want. I used a New Process 89mm 4 spd od and it fits well but is side linkage and I had to relocate pedals. If your b/h is old pattern, you could take the Jim Proffit approach and use adapter plate and **** T-OD trans. Rick's rear end idea works, but decide if you will stay six lug, otherwise upgrade to a more modern Camaro r/end. Axles and brake parts can be an issue if you go Rick's route-- but it is the most authentic looking. | | |
