0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Would someone please explain to me how the replacement oil pressure line fits together? This is for a 216 engine. It doesn't look exactly like the original and I don't want to wreck anything.
It seems like the nut slips over the line, and then a cone shape bushing fits on the very end of the line. Is this correct?
The bushing doesn't want to slide over the line fully, and it seems like it will fall out of position, fall and the floor, or somehow not create a proper seal. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Can ou post a pic? Here is a picture from Denny's website of what the original fitting looks like. http://www.pbase.com/dennygraham/image/137095044/largeyou have a separate cone shaped bushing? | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Yeah, the kit came with 1/8" tubing that slides through the firewall, then the nut slides on, and then the bushing slides on.
Upon closer inspection, the bushing was not sliding over the end of the tube because the tube was slightly out of round when it was cut. I will post pics later.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You are talking about the oil line for the oil pressure gauge??
John | | |
