0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | I am in the process of just finishing installing a 261 into a 1950 1 ton pickup... I had asumed that a standard rochester air filter would work but the 261 specific rochester has a larger inlet flange
Did they make a oil filled air cleaner for these engines when used in trucks or are they the dry filter element type?
Anyone have an oil filled air cleaner specifically for a 261 rochester?
Old Truck addict 1950 chevy 1 ton napco 1956 gmc 1 ton dually napco 1954 chevy 3/4 ton napco 1957 gmc civil defense napco panel
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have a Rochester carburetor that has a center post for mounting the air cleaner?
I do not know about those standard Rochester air cleaners.
If you have a carburetor that allows the air cleaner to clamp around the top: oil-bath and oil-wetted air cleaners were standard equipment (or optional equipment) depending on the size/model of the truck/engine.
Once you know what you want/need, post a Want Ad in the Swap Meet.
