5 members (Lugnutz, F100Ranger, 55shaker, Otto Skorzeny, Steelonsteel), 88 guests, and 4 robots.
Topics128,140
Posts1,056,466
Members48,441
Last fall I installed new Steele door gaskets. The doors do not seem to latch unless I really slam it while pushing at the latch. I loosened up the latch a bit by moving it outboard enough that it rattles slightly. Still difficult to close. The crack between the door and the cab seems even at about 1/4 inch. Help please - Thanks - Scott
55 1st Chev.
Junior Member
Junior Member
I'm going to be tackling that same project real soon...
I had the same problem on a 51 after installing new door seals. Adjusting the striker was no use, the problem was worn door latches.I don't know about 55 latches, but the ones on a 51 have a latching mechanism with a pawl that latches on piece of steel like a saw blade. All the teeth were worn in the area that normally catches.New latches solved the problem for me.
Well I thought someday I will be installing new
weatherstrips around my doors on my 53...
There was a fellow in 2001...that posted this..
He had also used steelrubber and was told that
oh yes the rubber need to relax and settle in.
He found out that there were two different thick-nesses.....#70-0331-73...1/2"
#70-0145-73...11/16
Of course using the thinner one as he posted was
the answer...Now I don't know because he never
got back to the list....Hope this will help you
out...
1946 chevy 1/2 ton panel
1937 ford coupe
