1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Ok, so I'm refitting the drivers fender and inner skirt on my 52 3100 and was looking through my factory assembly manual. I get lw, lock washer, nut and bolt etc. But what does pw stand for? Also should all of the bolt holes pretty much line up? Having a bit of trouble getting the bolt in the top hole for the skirt to cowel?
Thanks joe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no idea about the 'pw', but yes, everything should line up, make sure you're assembling all the front clip loosely before you tighten anything, allows for pushing pieces around to gain that silly millimeter here and there
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | PW is their abbreviation for Plain Washer, in other sheets of the TF manual it's called FW...Flat Washer. Flat washer is correct, plain washer is not. This is an example of lack of standardization in the design/drafting dept. at the time. Mil specs and SAE standardization for hardware was just starting to be developed at war time and that would include nomenclature. (AN960 Washer, Flat.... Approved Feb 1942) Alignment: Stay loose as Bill says and use a round tapered tool thru all pieces to align, like a bridge worker aligns girder rivet holes. In your case, it will allow some sheet metal pieces to slightly "stretch/buckle/twist" into alignment. The holes are called clearance holes. They are, of course, larger than the bolt. All assemblies, of any kind, have clearance holes to allow for hole location tolerances in each piece and the holes will not really be exactly concentric when bolted. Very normal what you are experiencing. Just jiggle, wobble and shake hard as bolt is inserted. You will discover which bolts want to go in first and which last.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Plain Washer...Flat Washer..learn something every day Thanks!
Steve H
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This is where body bolts come in handy. They are tapered at the end but the thread extends down to the end. It makes it much easier to align things as they go together. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | As bartamos posted : PW most likely means Plain Washer (Cadmum plated) | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Don't listen to bart. PW stands for phender washer. He's working on a phender, right? (Sorry buddy, I couldn't resist yanking your chain.) I enjoy reading the old manuals, before technical jargon was fully standardized. It gives you a flavor of how differently people talked sixty-some years ago. However it does make it challenging to decipher what they wrote at times. bart's friend, Carl
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Back in the day, PW meant something different altogether. Carl, you are stretching Cletis' patients! You are being phoolish.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | PW is their abbreviation for Plain Washer, in other sheets of the TF manual it's called FW...Flat Washer. Flat washer is correct, plain washer is not.
(AN960 Washer, Flat.... Approved Feb 1942) ANSI/ASME B18.22.1 also covers washers. The ANSI standard defines Type A, B & C Plain Washers, no mention of "Flat Washers" PW and FW are both correct, just depends on which standard they were using for the washers at that time. http://www.ansi.org/about_ansi/introduction/history.aspx?menuid=1 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Back then, they did not have B18.22.1, The name was whatever the drafter wanted to call it. In my manual, pages right opposite each other have the same washer called plain and flat with two different drafters. They don't list the part no. Most of the vendors who sell B18.22.1 call it a flat washer on their websites. Some people give the diameter as how "wide" a circle is. If that's OK, then plain is OK. Just going by what I was taught many years ago by Elmer Sperry's Company, the person who coined the word "Automotive" in "Society of Automotive Engineers", as an early SAE member. Nice, but all trivia. To me "Wide" is incorrect and "Plain" is incorrect. Like "Original" is to others
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Lol, thanks for the replies. Gotta love this place, good info and good light hearted ribbing in the process. | | |
