5 members (Charles in CA, mick53, Gray_Ghost, BC59, klhansen), 168 guests, and 1 robot.
Topics128,113
Posts1,056,277
Members48,439
#1036578 06/19/2014 4:12 PM
Hey all,
Recently picked up an all original 1952 3100 with the 6 volt electrical still in tact and working great...except for one thing. The headlights only work on low beams. When I hit the dimmer switch, the light comes on the dash indicating that high beams are on but the headlights go dark.
On suggestion from a friend I purchased a new dimmer switch and installed it last night. Still the same thing...low beams work, high beams do not.
Any other suggestions? Not sure if the headlights are original or if that could even be the problem area.
Thanks!
js4boys #1036584 06/19/2014 4:33 PM
did you check the function of the old switch with a meter? have you done continuity checks on the wiring? have you tried changing one or both bulbs? you're the only one that can put hands on the problem, and an ohmmeter should solve it
js4boys #1036601 06/19/2014 5:11 PM
Are there any connectors between the fuse box or whatever system it uses that could be dirty? I had a similar issue on my '62 Bel Air, and the fix was to clean the connectors on the back of the fuse box. This was after I changed the headlights, dimmer switch, fixed the grounds, etc. Check all connectors first, and get friendly with the multimeter and test light.
My 46 GMC on Photobucket
