7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series),
114
Mod | | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 19 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 19 | Stovebolters, Thanks for all the help thus far. Thanks to al that I took my old 50 chevy 3600 for its first drive in almost 20 years.
Problem is that when I top 30 mph the whole truck starts shaking. Now it has a 12 bolt rear end that the previous owner put in it and my guess would be improper pinion alignment but I want to know what else to check.
Of course I will also make sure the wheels/tires are balanced but any other thoughts and any ideas how i can narrow this down. Thank you Rob
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sorry you've had some problems on your maiden voyage!
You might be on the right track regarding the pinion angle etc.
It's a process of elimination as I'm sure you know,make sure the tires are not flat spotted from possibly sitting underinflated for so long,sidewall condition etc. They may well be 'out of round' or starting to break down through age/dry rotting etc. Jack the truck up and spin the wheels,they'll soon show if there's a problem..
Good luck. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | do you have bias ply tires that sat in same spot quite awhile? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Worn out front end parts. King pins, tie rod ends, steering linkage, etc. Tires flat spotted or knotted up.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The most important question is: Is the vibration in the steering wheel, or in the body (the seat of your pants)? If it's in the wheel look to the front end or front tires, if it's in the body look to the rear end (including rear tires) or driveline. Can you drive through it, or does it get progressively worse as you go higher speeds?
It could be anything from driveline vibration, unbalanced tires, separated tire, etc., etc. | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | It could be anything from driveline vibration, unbalanced tires, separated tire, etc., etc. even something as simple as putting the slip yok turned on the driveshaft wrong, when the U-joint caps are misaligned, front u-joint to the back u-joint; that can cause vibrations and are tough to figure out. | | | | | Joined: Feb 2014 Posts: 19 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 19 | all good replies...thank you. Definitely not in steering. Will let you know what I find out. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Your 3600 should have a two piece driveshaft, closed in front and open in rear. I would pull the rear wheels and open section of the driveshaft and rev engine to 2500rpm; no vibration then all is good. install driveshaft and rev, install wheels and tires and rev. Everything in the rear is now eliminated except tire trueness. We have an old spin balancer which can be used to check out all four wheels and if you have an old timey shop near you they would probably have one but if not the balance/trueness will be trial and error with driving. However, before driving jack up each wheel and set a beverage can (regular or "Lite") as close to the tire without touching and spin the tire. The trueness will be obvious and if you look closely you can also see any runout (wobble). I believe in orderly elimination rather than willy nilly.
Evan
