1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#1036394 06/18/2014 9:28 PM
Is there some place to buy the ends, that go on the pig tails, for the dash lights? Don't want to spend $3 for each pig tail, just need ends and will make my own. 53 3100 root
root #1036406 06/18/2014 10:35 PM
you should be able to get sockets at a local parts store, although you'll mostly find the plastic ones - if your metal sockets are salvageable, you can also get the actual inside electrical bits to rebuild them .... or you can try a post in the parts wanted and see if you can find some good originals
root #1036415 06/18/2014 11:29 PM
Ex Hall Monitor
Ex Hall Monitor
Item #23. They have a $20 minimum order for first time buyers.
root #1036419 06/18/2014 11:55 PM
I think he just wants the little ends. So at 25 cents each, I think you will have to buy 80 of them. lol.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
root #1036428 06/19/2014 12:20 AM
you can get those "button" contact ends at most parts stores, bare or with wires attached, also as a complete set, 2 contacts with wires and the round cardboard/plastic they sit in
root #1036491 06/19/2014 3:44 AM
I have been looking for those things for a long time so that I could just crimp them on myself. I finally picked up a set at advanced auto. They come as part of a tail light replacement part but you'll get two ends out of the deal.
root #1036553 06/19/2014 2:10 PM
ojh Offline
Keep your sockets, they are much higher quality than replacements. I get the individual pieces from American AutoWire, they have the little nubbins, springs, insulator board etc to rebuild the entire light.
A shop is where you wash your hands before you pee.
root #1036717 06/20/2014 2:56 AM
Thanks for all the input, looks like i will look into American Autowire tomorrow. ynz,s yesterdays parts has them at $.25 each but shipping is $12 plus calif. sells tax. Root
root #1036973 06/21/2014 4:44 PM
ojh Offline
If you can't get them give me a shout, I have extra and can send you enough.
root #1037104 06/22/2014 1:47 PM
Ex Hall Monitor
Ex Hall Monitor
I ran into that the last time I ordered a few. I called them directly (they have a third party that handles their shipping) and they put them in a standard envelope for a couple of bucks shipping. Of course I'm a return customer so the $20 minimum doesn't apply. I prefer the solder on type of terminal that YNZ sells over the crimp on.
root #1037189 06/22/2014 9:14 PM
Sir Searchalot
Sir Searchalot
In general, crimp gives mechanical strength and can be soldered for electrical reliability. You can see in Bill's link that the contact has a strain relief crimp for the insulation and a bare wire crimp. This bare wire crimp can be soldered if you wish but is not necessary. Very reliable without solder for automotive use. But it will not "fly".
root #1037201 06/22/2014 10:20 PM
any wire terminal can be soldered, and in a lot of places should be, but terminals designed for crimping on bare wires work fine, if properly covered with good heat shrink, and mechanically strain relieved as noted, which is usually accomplished by making the crimp catch both bare wire and wire coating, with a long enough 'barrel' or 2 separate crimps - heat shrink tubing adds to the security
