3 members (Hotrod Lincoln, 2-Ton, 1 invisible),
63
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Is there some place to buy the ends, that go on the pig tails, for the dash lights? Don't want to spend $3 for each pig tail, just need ends and will make my own. 53 3100 root | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you should be able to get sockets at a local parts store, although you'll mostly find the plastic ones - if your metal sockets are salvageable, you can also get the actual inside electrical bits to rebuild them .... or you can try a post in the parts wanted and see if you can find some good originals
Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Item #23. They have a $20 minimum order for first time buyers.
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I think he just wants the little ends. So at 25 cents each, I think you will have to buy 80 of them. lol.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can get those "button" contact ends at most parts stores, bare or with wires attached, also as a complete set, 2 contacts with wires and the round cardboard/plastic they sit in Bill | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | I have been looking for those things for a long time so that I could just crimp them on myself. I finally picked up a set at advanced auto. They come as part of a tail light replacement part but you'll get two ends out of the deal. | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | Keep your sockets, they are much higher quality than replacements. I get the individual pieces from American AutoWire, they have the little nubbins, springs, insulator board etc to rebuild the entire light.
A shop is where you wash your hands before you pee.
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Thanks for all the input, looks like i will look into American Autowire tomorrow. ynz,s yesterdays parts has them at $.25 each but shipping is $12 plus calif. sells tax. Root | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | If you can't get them give me a shout, I have extra and can send you enough.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Thanks for all the input, looks like i will look into American Autowire tomorrow. ynz,s yesterdays parts has them at $.25 each but shipping is $12 plus calif. sells tax. Root I ran into that the last time I ordered a few. I called them directly (they have a third party that handles their shipping) and they put them in a standard envelope for a couple of bucks shipping. Of course I'm a return customer so the $20 minimum doesn't apply. I prefer the solder on type of terminal that YNZ sells over the crimp on.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | In general, crimp gives mechanical strength and can be soldered for electrical reliability. You can see in Bill's link that the contact has a strain relief crimp for the insulation and a bare wire crimp. This bare wire crimp can be soldered if you wish but is not necessary. Very reliable without solder for automotive use. But it will not "fly".
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any wire terminal can be soldered, and in a lot of places should be, but terminals designed for crimping on bare wires work fine, if properly covered with good heat shrink, and mechanically strain relieved as noted, which is usually accomplished by making the crimp catch both bare wire and wire coating, with a long enough 'barrel' or 2 separate crimps - heat shrink tubing adds to the security
Bill | | |
