8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible), 104 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
#1035981 06/16/2014 10:45 PM
ojh
Offline
I'm accumulating for a rear gear change, where can I get a shim pack that has a 'carrier pack' where the shims go in as pack and not individually.
A shop is where you wash your hands before you pee.
ojh #1035982 06/16/2014 10:49 PM
year?
size of truck?
rear end type?
ojh #1036098 06/17/2014 1:07 PM
ojh
Offline
'52 3100, stock rear
ojh #1036114 06/17/2014 2:14 PM
Patrick's. But, his packs include thicker than factory shims to account for his gear set. Give him a call.
ojh #1036338 06/18/2014 3:58 PM
GP, a shim "pack" to me simply means a number of shims of differing thicknesses that you pick and choose what you need to get to the final proper clearances. You cant simply assume you need x, y, and Z thickness shims. You have to shim the pinion bearing to proper clearance and each axle setup is different to some degree.
Patrick's tells you that his gears are setup so that you probably have to add X thickness shim to the factory stack as a starting point, but must check clearances and add/subtract as necessary. It's a painstaking process, but absolutely necessary.
ojh #1036959 06/21/2014 3:04 PM
ojh
Offline
I may be using the wrong term. In other rears I can find shim sets that you add shims to a shim carrier, if you need to swap a .010 with a .008 you pull the entire shim pack carrier out replace the shims, the carrier lets you drive the shims in or pull them out as group so you don't have to deal with individual shims.
