| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 1 New Guy | | New Guy Joined: Nov 2013 Posts: 1 | Well I got my new 4.10 gears in the rear end. From a 72 3/4 chev. I got the info I needed here on stovebolt. Thanks for the help. The truck crusies at 60 mph now . Took 2 1/2 hrs for the complete job. First one I ever did. The Chev service manual helped to. Now I can cruise and not feel like I need to shift gears | | | | | Joined: Feb 2014 Posts: 34 New Guy | | New Guy Joined: Feb 2014 Posts: 34 | Are you running the 1950 rearend? If so what bearings for the pinion? I have a 48 that needs the pinion bearings replaced and I can't find bearings. Thanks | | | | | Joined: Feb 2014 Posts: 34 New Guy | | New Guy Joined: Feb 2014 Posts: 34 | Will the 67-72 pinion and bearings fit in my 48 rear end? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | | | |
