0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | I'm definatley not a Muncie Guru, but have had a few of them over the years, and have one in my '55 pickup now. I'm wondering if the stud is an integral part of the shift shaft or a screw in stud? The one in the reverse shaft in your newer one has either been replaced or the stud was unscrewed and a bolt substituted. If the broken stud can be unscrewed out, you are home free. I would think that the shaft with the broken stud can be drilled and tapped, but the tranny would most probably need to be removed from the truck and disassembled? Wish I could be of more help, maybe a Muncie Guru will! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | They either came with the stud or bolt, never a mix of both. I think that drilling it out would be difficult even if done with a drill press. I would pull the tail shaft off the transmission then get a better look at the broken bolt/stud. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Thanks for your input guys. I am being told by fellas that sell and rebuild these that: * It's not a screw in stud, the 5/16-18 threads are part of the shaft, and the shaft is hardened steel. * The tail housing cannot be put back onto the transmission while the transmission is in the truck, due to a "spring and ball" arrangement inside the tail housing. At least I'm learning alot | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Gotta be pretty hard to break that stud, guess maybe if the nut worked loose? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Agreed. It's been cracked for a long time, it has heavy rust in the cracked area.
This trans was made in 1965. They changed the design in '69 from a 5/16" UNC thread to a 3/8" tapped hole... doesn't sound like much, but it increases the strength by 44%. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I was able to repair the busted threaded portion of the reverse shaft discussed above by drilling and tapping the shaft while the transmission was still in the truck. I also confirmed what the Muncie guru's were telling me, the original OEM shaft design was not a screw in stud. Numerous sources told me that the shaft is hardened, and I believe it is, but not very hard. Drilling was fairly easy, tapping was a bit unnerving, but successful nonetheless. The repair was made easier by the exhaust routing I did quite a while ago. By simply unbolting the exhaust from the headers and hangers I was able to access the transmission easily. http://i645.photobucket.com/albums/...%20Transmission/DSCF1918_zpsc3f69e74.jpghttp://i645.photobucket.com/albums/...%20Transmission/DSCF1920_zps6cb5b006.jpg | | |
