| | | Forums66 Topics128,180 Posts1,057,165 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | I am putting a Langdons rebuilt T5 into a 37 sedan behind a 61 261 that replaced the original 216. The engine/tranny weight was/is supported by the front plate engine mounts and the mount at the rear of the tranny. The crossmember at the rear of the engine that's connected to the bell housing and framerails apparently absorbes the rotational torque of the engine and does not support any weight of the engine. The T5 tranny case and the four tranny/bell housing mounting ears are made of aluminum. MY CONCERN IS THE BREAKING OF THESE EARS SINCE THE ENTIRE WEIGHT OF THE ENGINE AND TRANNY IS SUPPORTED BY THE FRONT PLATE AND REAR TRANNY MOUNTS. Thanks in advance for any comments | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Well, you are talking about a car, right? Don't know. My 37 truck has a 261 in it with a T-5 behind it and I've had no problems. A car could be a different story and I doubt if you find any information about a car on this site since it's a truck site.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | You need to support the engine and transmission. The original mounts won't support it properly. The 261 should have engine mount bosses on the side of the block like later model 230/250 engines have. You need an aftermarket crossmember for the engine and then a crossmember for the rear of the transmission.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If I understand it properly, you need a way of supporting the rear of the engine. Have you looked into using a later bell housing withthe side mounts? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Here's a company that sells quite a lot of engine mount kits, I'm sure they have what you need. The pass cars lack the beefy crossmemeber that trucks use making eng swaps a bit more challenging. Side support is the ticket with your 261. http://www.chassisengineeringinc.com/1937-1939-chevrolet-car/?sort=featured&page=4
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Ryanz,
I guess you know that the existing cross member for the side mounts will interfere with your oil pan? | | |
