| | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 120 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 120 | Picked up a 41 chevy out of a barn a few months ago that was parked there since 1996 and work on it every Monday, rebuilt the entire front suspension and steering so far.
Got a lot done yesterday, rebuilt carb last week and this week I installed a new fuel pump bent all new fuel lines and installed dual fuel filters then after cleaning the gas tank out I put fresh gas in it and she fired up and runs pretty good but I have a sound in the transmission that may be why it got parked, has a low pitch roar kinda bearing sound, changed fluids and no different but goes away when ya push in the clutch, have it on jack stands to go through the gears and it's bad in all of them what do you guys think it is? main shaft bearing? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Through out bearing? Is the clutch adjusted? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Don has the best answer..... Throw out bearing... John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | but goes away when ya push in the clutch Throwout bearings generally get louder when you step on the clutch. By stepping on the clutch you are stopping the main shaft and cluster from turning. I would say that you have bearing problems in the trans.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2014 Posts: 120 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 120 | thanks for the confirmation! I guess after I get the brakes finished I will get a crash course in this old transmission and I hope they still have bearings available for an old granny 4 speed  | | | | | Joined: Feb 2014 Posts: 120 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 120 | Or maybe it's a good candidate for the T5 swap I just read  | | |
