| | | Forums66 Topics128,052 Posts1,055,770 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 25 | Well I got the truck (51 chevy 3104) running good enough not to worry about going somewhere  . Now I am trying to figure out what special care I need to do when spending the night at a motel. I would like for the truck to be there the next morning without any new scratches. I do have an antenna and driver side outside mirror installed. So for you travelers - What if anything do you do when spending the night on the road to protect your old ride. Some sort of cover??
Chuck, '51 5 Window 3104 '47 Chevy Fleetmaster
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ...nothing... Did lock it, and tried to park where I could see if from the room. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If you're worried about it getting a scratch on it then you should have it on a trailer, if your worried about getting it wet or dusty then your should have it in an enclosed trailer, if your worried about getting it stolen then you should have an alarm installed. DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | Install a hidden kill switch. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | When overnighting we lock the doors, flip the hidden battery disconnect, and use "the Club" on the steering wheel. And when possible park under a light away from the building where others don't park.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Lock it and don't worry about it. I have done extensive traveling in old vehicles and have never had a problem with vandals or thieves. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I invested in a club also. I got the model w/the double hooks at each end. I fit it to where the two steering wheel ribs are between the hooks. A crook would have to cut both steering wheel ribs to get it out and it wouldn't be very driveable then. Park it close to your room and in a way that makes it hard for a wrecker or trailer to get to it. If you still have the stomp starter odda are young crooks wouldn't even know how to start it  Good luck Dave | | |
