6 members (Gdads51, MickeyP, 50Chevy3100, HandyAndy, Joe H, 1 invisible), 68 guests, and 1 robot.
Topics128,090
Posts1,056,015
Members48,430
#103239 11/25/2001 3:01 AM
I need to replace the rear cargo area rubber floor mat on a 1959 GMC suburban/carryall.
Has anyone done this before. Where can I get an original style rubber or close to original?
john
#103240 11/27/2001 6:04 PM
John,
I hope someone answers, cause I have the same question for a 52 Suburban.
Jim
#103241 11/27/2001 11:40 PM
I am also interested in an answer, for a '54 suburban.
What was the color of the mat in a '52 suburban; brown, beige? The mat in a '54 suburban was black,
Jim Carter use to carry a mat but not any more. If there are enough people interested, a shop in Canada might be interested in milling some rubber to match. Send me e-mail : [email protected]
Tim
#103242 11/28/2001 2:29 AM
Anonymous
Unregistered
Anonymous
Unregistered
I need two mats for 50&52 suburbans smile
#103243 11/28/2001 7:11 AM
The only source I have found comes in strips and is not cheap! ...........g grin
http://www.dickblick.com/zz404/04/products.asp?param=0&ig_id=1857
#103244 12/03/2001 8:37 PM
I need mat for 50 Suburban. Mine was light brown. This post really brought out the "Burb Bunch" cool Cool, hi guys!
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#103245 12/04/2001 6:28 AM
HEY BUDDY CONTACT [censored] BLICK AND ASK FOR A SAMPLE. I KNOW THE PIC IS BAD BUT THIS IS AS CLOSE TO THE ORIGINAL AS I HAVE FOUND. WHO KNOWS MAYBE THERE IS ENOUGH OF US WE CAN BUY A ROLL. UNFORTUNATELY IT COSTS MORE THAN MY BURB! BTW I HAVE A 49 AND 51 BURB AND A 49 CE. .............G grin
#103246 12/04/2001 9:35 PM
GM,
Thanks for the info. I had thought my suburban "mat" was dried-out rubber. A more careful look at pieces I removed does seem to confirm that it is linoleum. The source for a replacement that I contacted was for a rubber mat.
The pieces of mat I have from my truck do not have a burlap backing. It is backed with something that looks like roofing tarpaper (which might explain the tarlike mastic used to adhere the mat to the plywood floor.
Here is another source of (burlap backed) linoleum in several colors. I will call him tonight and post what I find out.
Thanks, Tim
http://www.battleshiplinoleum.net/
#103247 01/15/2002 8:17 PM
Sorry this has taken me so long but I was trying to find someone with knowledge of the original rear floormat material in Advance Design Suburbans. No luck. So, I contacted Battle Ship Linoleum (Tony Lauria, 610-268-3441).
The good news (for brown/beige mats):
Tony was not certain what material was originally used in Suburbans but he kindly sent me samples of his products and an article from "Woodie Times" about putting grooves in his product in a restoration of a 1951 **** Country Squire "Wooie" ('49-51 were similar models). The sample (with grooves that were routed by one of his customers) is light brown (dark beige) in color and the material thichness is a good match to my mat (0.125" : 3.2mm). The routed grooves almost perfectly matched my mat.
The bad news (for black mats):
My 1954 Suburban has a black mat (earlier Advance Design years were light brown, I think). Tony does not carry black mat in 0.125" thichness but he carries it in 0.100" thichness. This thichness is thinner than the mat in my 1954 Suburban and it is probably too thin to rout.
I am fairly certain that Tony's mat came from Armstrong and I have contacted Armstrong to find out if they have any more 0.125" black material (they supposedly stopped production/importation last March of this thichness in black). I will post any information I receive.
If you are interested in the brown material, it costs around $5 per square foot and the AD Suburban's mats are approximately 62" x 82" (5x7 feet = 35 square feet = approximately $175 plus shipping). You will have to rout grooves in the material but Tony will send you a copy of the Woody Times article (it is very useful).
Please note that I have no knowledge of the rear mats in earlier or later Suburbans (or station wagons or panel wagons).
Tim
