4 members (GDW, Gdads51, ‘37ChevyPU, Shaffer's1950), 119 guests, and 1 robot.
Topics128,139
Posts1,056,455
Members48,441
#1031545 05/27/2014 7:39 PM
I can't seem to get my speedo to work? I can get it to read when I turn the cable by hand. I can also see that it is turning from the transmission, when I am driving, but when you hook them together the speedometer won't register? Any suggestions.
thanks
tom
Tom
What year vehicle?
Will the odometer work?
It's a 1939 chevrolet half ton with a 235 engine. I don't think the odometer works either.
Tom
The cable isn't broken inside the cable housing somewhere?
No, I can turn it by hand and it also spins when the truck is moving if you unhook from the speedo.?
Tom
The inner cable might be too short. If it wont engage both ends it won't drive the speedometer. Both ends need to have a "square" shape to them and need to go into the drive gear and speedo head far enough to drive them. If you can run the speedo with a drill and the cable turning when disconnected it might be too short.
Steve H
I hooked the drill up and ran it in forward and nothing happened. When I reversed the drill the speedo worked?
Is that correct or is something backwards?
thanks!
Tom
Thanks! Is there anyway to test the speedometer drive?
Tom
Not sure I understand what you mean by speedometer drive.
If you hooked up the cable with a drill , ran it in reverse. The speedometer and odometer should turn.
What I call the drive is where it screws into the transmission.
Tom
Ok
Not sure , someone else might chime in for you
When I had my problems recently with my speedometer I had the speedo out for a few days but still drove to work.
I could see the inner cable turning as I was driving.
Hopefully someone will have a better answer for you
Thanks for your help!
Tom
I was having the same problem and found my needle was pressed against the glass when I installed it. it worked uninstalled by hand and drill but didn't work when I put it all together and drove. It was a replacement needle so I just shaved it down a little and now it works.....not really accurate but it works....
