2 members (Gdads51, 1 invisible),
123
Mod | | | Forums66 Topics128,137 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | I can't seem to get my speedo to work? I can get it to read when I turn the cable by hand. I can also see that it is turning from the transmission, when I am driving, but when you hook them together the speedometer won't register? Any suggestions. thanks tom
Tom
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What year vehicle?
Will the odometer work? | | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | It's a 1939 chevrolet half ton with a 235 engine. I don't think the odometer works either.
Tom
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | The cable isn't broken inside the cable housing somewhere?
John | | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | No, I can turn it by hand and it also spins when the truck is moving if you unhook from the speedo.?
Tom
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | The inner cable might be too short. If it wont engage both ends it won't drive the speedometer. Both ends need to have a "square" shape to them and need to go into the drive gear and speedo head far enough to drive them. If you can run the speedo with a drill and the cable turning when disconnected it might be too short.
Steve H
| | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | I hooked the drill up and ran it in forward and nothing happened. When I reversed the drill the speedo worked? Is that correct or is something backwards? thanks!
Tom
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | Thanks! Is there anyway to test the speedometer drive?
Tom
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Not sure I understand what you mean by speedometer drive.
If you hooked up the cable with a drill , ran it in reverse. The speedometer and odometer should turn. | | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 | What I call the drive is where it screws into the transmission.
Tom
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Ok
Not sure , someone else might chime in for you
When I had my problems recently with my speedometer I had the speedo out for a few days but still drove to work.
I could see the inner cable turning as I was driving.
Hopefully someone will have a better answer for you | | | | | Joined: Jan 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 35 |
Tom
| | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I was having the same problem and found my needle was pressed against the glass when I installed it. it worked uninstalled by hand and drill but didn't work when I put it all together and drove. It was a replacement needle so I just shaved it down a little and now it works.....not really accurate but it works.... | | |
