| | | Forums66 Topics128,078 Posts1,056,283 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Does anyone have a break down of whats in each sect. of the factory manual? No index, so its a pain.53 3100 root | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | root,
It takes a little to get used to how the FAM is organized.
The pages of illustrations at the front of the Manual are the index. Those pages at the front are organized into categories or topics and they reference different sections and pages in the Manual.
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Here's the list I came up with. My book was falling apart so I separated the sections with tabs in a large 3 ring binder. SECTION 0 INDEX & INSTRUCTION SECTION 1 CAB & SHEETMETAL SECTION 2 CHASIS SECTION 3 FRONT SUSPENSION SECTION 4 REAR SUSPENSION SECTION 5 BRAKES SECTION 6 ENGINE SECTION 7 TRANSMISSION SECTION 8 FUEL & EXHAUST SECTION 9 STEERING SECTION 10 WHEEL & TIRE SECTION 11 CHASIS SHEETMETAL SECTION 12 ELECTRICAL SECTION 13 RADIATOR & GRILL SECTION 14 BUMPER & SEALING
I added a Section 15 for Bed info | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Good idea.
Every time I use a page I write the page number and subject on one of the blank pages in back. Makes it easy to find next time. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I'm curious. Are the Assembly Manuals referenced here the same as Shop Manuals for say pre-46 trucks? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no Sparky, the assembly manuals for the later years are the spec and procedure technical drawings for the assembly line supervisors, things like this and like this [from 55.2-59 manual] - unfortunately the earlier year collections seem to have been lost Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It is rumored that the assembly manuals were not available for distribution. The ones that are reprinted were supposedly smuggled out of the plant. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Thanks, guys. Sure stinks that without that factual info some are left to guess. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | thanks everyone, i have a disk and not the book, so writing in the back is ????. chadkiser thanks, printed it out and put in the front of my disk. root | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | There is an example of how technology is not better. I'd much rather thumb through a book then try and find the right page by navigation 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | I would like to have an assembly manual, but I am pretty disappointed with my factory service manual. It is more like a giant owners manual. Too little info covering too many years, and models, with just bits, and pieces of each one. The service manual for my 14 Tahoe is several books for like $500, and still leaves a lot to the imagination.
