1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#103119 10/15/2001 7:51 AM
:confused: Putting together a 1946 Pickup. Street rod, so I am making my own radiator support. Can someone tell me how this is normally mounted? Does the radiator support bolt directly to the frame support or is there a block of wood, rubber, etc. between?
#103120 10/17/2001 2:18 PM
I don't know about the '46 but '47 to '53 had a 1/4" think rubber under the mount to the frame for vibration.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#103121 10/17/2001 3:57 PM
Fred
52 3600
69 C-10
#103122 10/18/2001 3:16 AM
I looked at the radiator support pads at AmericanClassic.com and it confused me. The pads are 4 x 1 1/2 inches and there are two of them. Where do they go? Are these the ones that go between fender supports and radiator support or between frame crossmember and radiator support. If the latter, why are there two? The support mount I was asking about is the one at the crossmember.
#103123 10/18/2001 7:47 AM
The rubber pad (or pads) go between the radiator support and the crossmember. Wish I could help you more, but my truck is a 52. It has basicly the same setup, but only had one thick pad with some shims. You might have to play with the thickness, it does make a difference on your hood to fender alignment.
Fred
52 3600
69 C-10
#103124 10/18/2001 3:59 PM
Fred is right the pad goes between the support and the frame crossmember. On my 46 there is only a thin rubber pad there which causes the front end to sit too low, which causes problems with the bumper supports hitting the top of the holes in the filler pannel below the grille. I need to put in a thicker pad to raise the front so it is aligned properly. This also affects the alignment of the hood.
Good luck
George W
#103125 10/18/2001 9:12 PM
Rubber cut from the side wall of a discarded radial tire is better quality than the stuff you buy.Make sure the cab isn't set too high.You can change the cab angle slightly to help with the hood fit. The original rubber is fairly thin stuff.If you have to shim a lot use something rigid with the rubber ,not just thick rubber.The original core support bolts had stiff springs on the bottom to allow some flex.
#103126 10/18/2001 10:57 PM
I have seen people use long bolts with washers and a valvespring for tension and flexibility.
#103127 11/13/2001 11:30 PM
Thanks to everyone who answered.
