| | | Forums66 Topics128,077 Posts1,056,012 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 25 New Guy | | New Guy Joined: Dec 2012 Posts: 25 | I'm sure this is real simple but is there a trick to installing the rubber bumper in the upper control arm of a 66 1/2 ton? Trying not to scratch up the new paint.  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Rubber tire lube. Most parts stores will have it, you may have to talk to the Commercial sales counter person to get it, as it's not usually an over the counter item. Apply it liberally to the part and swap the hole it goes in to, it should go in without too much trouble. Any excess will clean up with water.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Dec 2012 Posts: 25 New Guy | | New Guy Joined: Dec 2012 Posts: 25 | Thanks guys. Didn't think of that. I was thinking about it at work today and thought I try some liquid soap. This may be better. | | |
