| | | Forums66 Topics128,271 Posts1,058,416 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Well folks, I'm not sure what I did and I suspect I still have a hidden problem somewhere, so am looking for some good advice. I re-wired my '53 a month or so ago. Have had some strange problems. I followed the wiring instructions to a 't'. Converted to 12 volts. Bought a new AM/FM/Cassette radio that mounts in the dash hole from Classic Parts of America. Followed their instructions to a 't' as well and I've done my share of installing radios, so I know pretty much how to do it. However, the battery has gone dead a few times while sitting with the negative terminal disconnected. I'm at the point where I'm working to fire this truck up after 6+ years ot restoration. So, yesterday while working to get it to TDC for distributor installation, I found the battery dead once again. I put the charger on it and turned it on. Heard a crackle and looked inside the cab. Smoke was coming from the tape deck portion of the radio. I'm guessing it is toast and I haven't a clue why this happened. I need someone with some electrical expertise to tell me why the radio would get fried and also what would be causing the battery to drain power while the negative terminal is disconnected. I don;t know where to start diagnosing the problem. Any help would be much appreciated. Sure made short work of a $200 radio. I know it worked, too, as I had it on after I installed it and listened to some tunes while the battery was up. | | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | I forgot to mention that the in-line fuses in the radio wiring are still intact and didn;t even blow. | | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | I can think of no way the battery would discharge due to a external electricl drain while having only the positive post connected. I would suspect the battery.
I wonder if it is possible that the battery, the charger, or both have the polarity reversed. I have mistakenly hooked up a battery charger backwards before and charged a battery in the reverse polarity. This is easy to do with a charger that has color coded alligator clips that come off easily, comibned with a stone dead battery. This practice could lead to a battery not holding a charge, or you could just have a bad battery, even if it is new and charged correctly. The smoked tape player may be co-incidental, but I would double check polarity, and/or suspect the battery. A battery that goes dead with only one terminal connected, must be bad or have an internal short.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Rick: Is it possible you didn't actually fry the radio, but maybe there was/is a short next to or behind the radio giving the appearance that the radio was smoking. I've also had batteries that just don't hold a charge, especially those that are not used for a few years. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | One way the battery can discharge with the negative cable disconnected is for the battery hold-down to touch the negative terninal if it also is loose. This happened recently to someone on this forum. His actually touched both battery terminals.
It's possible the battery charger can put out too high a voltage if it isn't well connected to a battery, such as might happen if you just pushed the negative battery cable on without tightening it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe your battery is bad & the charger voltage ran away with out the proper load. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
