| | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Hello,
My new electrical harness gives directions on how to connect to an ignition switch with two contacts. But mine has 4 contacts, two on the top and two on the bottom.
Does anyone know how I wire this? Is there a standard for switches with 4 contacts?
I have a 1953 3100.
Thanks, Steven
1953 3100
Melbourne, FL Veteran
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The original switch had 2 leads - a hot-in and and an out to the coil.
You will have to use a continuity tester to determine the purpose of each connection/lead on your "non-standard" switch.
Do you have a mechanical/foot-actuated starter? Do you have an original 6v system or a 12v conversion? | | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Tim, I have a mechanical foot starter with a 6 volt system.
I tried to take the starter switch off the panel using tech tips, and it so 'on there' that it is bending the key.
1953 3100
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | using the key is to remove the lock cylinder from the switch body, taking the switch off the dash requires removing the retainer, maybe screws like a 54? that tech tip was written by a 37 owner sounds like the switch you got is a 'generic' type, as Tim says, you'll need to use an ohmmeter to figure what each terminal does, if there's a center pin that should be the battery +, if the switch has a spring loaded position there will be an unused terminal for that 'key start' function, another will be ignition when on and the other may be an accessory power terminal - ignition and accessory should be interchangeable and only show continuity when the key is on Bill | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | The last "generic" switch I put in had, 1, battery. 2, Accessory, (used to run the radio when the engine was off most likely). 3, Run, (every thing was on). And 4, Start, to the solenoid or for the Ford and Jeep types, Starter Relay. Most are labeled but not all. Use an Ohm meter to figure what is what. And.. red58 told you that already.
Steve H
