4 members (Otto Skorzeny, Rustnut, 78buckshot, DadsFirstPickup), 197 guests, and 6 robots.
Topics128,108
Posts1,056,236
Members48,437
On my switch there are 7 wires. One goes to the brake lights switch.
Can anyone clarify what this wire is and what it does.
TIA
Dennis
it gets the signal from the brake pedal that activates the brake light[s] via the signal unit .... unit allows that signal [power] on both lights unless a direction is selected, then it interrupts the selected side
Sir Searchalot
Sir Searchalot
As Bill said while I was typing smile A wire does go to the brake switch. The turn signal switch is sort of the heart of a portion of the lighting system. The same filament is used for stop and turn so if you are on the brakes and have the turn signal on, it "routes" the current to one side for brake and the other for turn. (it's a computer!) The other filament is run and park.
Thank you
Dennis
