| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Have any of you guys tried to repair the Gas sending unit on your Chevy truck. Mine looks like all that wrong with it is the flat metal strap that connects the terminal with the Resistor switch is broken. Just wondered has anyone ever soldered this with any level of success? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Focus, I haven't tried this repair. My thought would be this; If the strip have broken from years of sloshing, the other parts must be worn out too. For the cost and labor involved, it seems like sticking a brand new one in would be the best move. Why don't you be the first to fix this deal and let us know how it turns out. Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve tried fixing the reostat part without success. I have fixed them when the connections are bad at the mounting plate. I also have taken the reostat part from a salvage that didn,t fit the application & put in one that did. I don,t see why you couldn,t solder it back. Test it before you put it in with an ohm meter or hook it to the wire & ground & put it through the motion with someone watching the gauge. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
