1 members (Bill Hanlon), 48 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#1028355 05/13/2014 1:44 PM
Good morning folks. I'm having trouble sliding the engine in the last couple inches. What do you suppose the trouble is?
I'm using the engine leveller, and I heaved on it and wiggled it for about 3 hours. It just won't fit the last couple inches.
Do you suppose the clutch is mis-aligned? I used a socket and lined it up by eye, but I'm sure it's very close.
Any tips on getting this in would be appreciated, thanks.
You may need to rock the input shaft of the transmission to get it to align with the splines in the clutch disc. I find it easier to install the transmission after installing the engine....
My guess is that the clutch disk is out of alignment. you really need the proper alignment tool as there is zero room for error.
Sure enough I found the alignment tool in my box from the last time I did this.
I think the engine is close enough that the disk is sitting on the splines. The tranny is no more than 2 inches from the bell housing.
What would happen if I loosened the clutch bolts and then tried to poke the shaft in?
I think your hanging up on the pilot bushing. If you found your alignment shaft I'd pull it out and get things lined up and then stab it in.
Thanks for your help everyone. I aligned the clutch properly and in it went. Much easier the second time.
