4 members (Gdads51, 6inarow, klhansen, Cosmo), 106 guests, and 0 robots.
Topics128,052
Posts1,055,738
#1028302 05/13/2014 3:56 AM
I found out that my 51's frame is cracked on both sides just behind the cab support brackets. Which years s10 frames will my truck use to replace the cracked one?
Any year S-10. What size truck do you have? If it's a half ton, you need a regular cab longbox S-10 for the right length wheelbase. If it's a 3/4 ton, you need an extended cab shortbox S-10 for the right length wheelbase.
My 46 GMC on Photobucket
Weld it up.
