0 members (),
137
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 70 | I think I know the answer,but I saw this photo and had to ask,wondering if the one-ton wheel opening is the same: Flickr 1952 Chevrolet 1 Ton Flatbed | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | 1/2 - 1 ton are the same. The bigger trucks had larger fenders due to the increased tire size.
Bruce | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Depends on the year and tire size. My 1941 1 ton pickup has 17 inch wheels and the front and rear fenders are larger and rarer.
1/2 & 3/4 ton had 15 and 16 inch wheels with the same size fenders front and rear.
I would check a parts list. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The '41 is somewhat of an odd case, though, as the 1 ton truck (According to my sources, only a Panel was offered) was based on the 1 1/2 ton chassis, with lighter spring and tire equipment. Then again, if you go later, there was a 1 1/2 ton offered in the late '60s/early '70s that used the same body as the 1/2 through 1 ton trucks, with the difference being an HD suspension, larger brakes, HD rear axle, and heavier tires. To muddy the waters even more, there was also a 1 1/2 ton Express model (a very large pickup) offered during the '30s. In the case of the '52, the fenders are the same through 1 ton.
Bill Burmeister | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Like Bill said, I think for clarification we should stick to your truck in question, AD 1947-1955; then yes. 1/2 ton to 1 ton trucks share the same fenders and most cab parts.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Aug 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 70 | Thanks guys for answering that.When I saw the dually wheel on that truck,I thought that possibly it required a different fender. Flickr 1952 flatbed What size wheel and tire were on the one-ton dual wheel trucks? (Advanced Design) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 18" dual wheels on an AD 1 ton | | | | | Joined: Aug 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 70 | 18" dual wheels on an AD 1 ton Thanks,what was the tire size and/or diameter,and how did it compare to the smaller pickups? | | | | | Joined: Jun 2013 Posts: 50 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 50 | The truck in your link is a 1.5-2 ton with the 5 hand hole wheels so it should have a larger fender opening than the 1/2-1 ton trucks. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Oops! I missed the picture. Yep, I'd guess that's a 2 ton or if the picture was better detail you could tell if it's a 1.5 ton, it is one or the other.
Grigg | | | | | Joined: Aug 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 70 | Oops! I missed the picture. Yep, I'd guess that's a 2 ton or if the picture was better detail you could tell if it's a 1.5 ton, it is one or the other.
Grigg OK,that makes sense,that the photo was incorrectly labeled as a one-ton truck.The photo wasn't very clear...and the hood is open on the truck,but at my view the nose did not look like a big bolt. Did any one-ton truck come with dual rear wheels? | | | | | Joined: Nov 1995 Posts: 5,747 24601 | | 24601 Joined: Nov 1995 Posts: 5,747 | Yes, on the 1-ton Advance Design (which is what we are talking about), duallies were an option. Look in our Gallery and you'll find lots/many/some of them.
The open hood presents a nice clue -- the shorter shroud covering the top of the radiator and mounting the hood latch. On the 1-tons and smaller, the upper shroud is taller and more pronounced. On the Big Bolts, because of the taller tires needing bigger fenders which in turn require a bigger grille ... smaller shroud needed.
Like Grigg says, if we had more resolution to that photo so we could make out the detail of the front wheel hub, we could see if it is a bolted-on round cap (2-ton) or a screwed on hexagonal (?) cap (1.5-ton).
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
