1 members (Phak1),
186
Mod | | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Anyone know anything about Zenith carbs?? My 54 Burb has one and I need some parts(gaskets, needle seat, accel pump). Any kit numbers where to get any parts etc. Thanks! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | http://www.thecarburetorshop.com/Jon can help you. He is a member here and offers lots of good advise. You should get some numbers off the carb before you call. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is there a small metal tag attached to the carb?
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | There should be a round tag about the size of a dime riveted to the body of the carburetor (if it is a downdraft, probably on the airhorn). There should be two sets of numbers going around in two circles on the tag. The outer number is the GMC number which is not as useful as the inner (Zenith) number. The Zenith number will generally be 4 or 5 digits possibly but not always followed by a letter. The number may or may not be preceded by an O Examples: O-9866 O-9866A 9866 9866A O-12345 O-12345C 12345 12345C Watch the letters. A's look like 4's; C's look like zeros's. A good idea to take a pencil eraser to the tag, and then observe with a strong light, a good magnifying glass and a pair of "young eyes"  . Wish I still had the young eyes. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | understand the young eyes issue!! The number appears to be 14278 D its on a 1954 235 Suburban but their doesn't seem to be a listing for that mfg carb on those years for Chevrolet???? I just need a kit for it.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Zenith carburetors were not standard or optional equipment on 1954 Chevrolet Suburbans (or on any USA 235 Chevrolet engines).
The 248ci engine in 1954 GMC Suburbans used a Zenith carburetor.
If Jon does not know that code, good luck.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | I have no record of a Zenith 14278 with any suffix.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Well, following Jon's advice my numbers after good cleaning are 11275 D and I sure hope they come up somehow. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | GMC used replacement Zenith 14275 and also, 14475
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Walker Products lists a rebuild kit 778-608 for a Zenith 11275 and 11275A O'Reilly Auto Parts Amazon.com eBay store Wait to hear from Jon to see if this is correct. Jon probably sells a kit, too. | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Thanks for the heads up on kits-hopefully I'll hear from Jon and maybe he has something. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Zenith 11275 D is one of the Zenith universal carburetors. Consider yourself fortunate to have it, as it is one of the very best single carbs to put on a 235.
And while I try to avoid any advertising in the questions/answers portion of this forum, since others have mentioned me, yes, I do offer a rebuilding kit.
573-392-7378 (9-4 Mon-Tues central time).
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Jon need a assembly diagram for that carb....
thks.. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Jon need a assembly diagram for that carb....
thks.. As this is a universal replacement, no exact diagram exists; however, a generic diagram for a G.M.C. with a Zenith type 228 (carb type, not engine size) will be close. Try local library and an old truck Motors Manual. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I have a rebuild paper for the 28 and 228 if you need a copy.
Its a generic rebuild sheet.
From what I understand the 28 and 228 are basically the same except the idle circuits | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | An online pdf file for a Zenith Series 28-228. Right one?
Search Google for,
"Genuinepartscompany/1227942pdf"
Copy & paste it. Use the quotes. Should be the only Google result.
When you open the file, depending on your Browser, it may save the pdf file to your computer incorrectly as 1227942pdf.
Your computer can't open it because the . is missing.
Right click and rename the file, pick a name, and the name must end with .pdf
-Tom
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Jon where can I get a filter for this carb?? The onw that goes in the upper plate at the inlet??
thks
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | My truck initially had the inlet filter, but GMC issued a TB to remove them. I may still have it... can post pics but not for sale.
I've never seen one for sale. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | An online pdf file for a Zenith Series 28-228. Right one?
Search Google for,
Right click and rename the file, pick a name, and the name must end with .pdf This is a very basic and generic sheet and is basically a parts diagram. The one I have is like 6 pages with step by step directions. Protip: to get out the check valves use a 3.5 inch drywall screw and screw about 2 turns into it. The pull out. You're welcome  | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | This is a very basic and generic sheet and is basically a parts diagram.
The one I have is like 6 pages with step by step directions. It's the "Instruction Sheet" that is included in Carb rebuild kits that you buy at your FLAPS. Sorry, I thought this was the assembly diagram that was requested, since it included..... disassembly, cleaning, reassembly, special instructions, float level adjustments, and 5 pics showing adjustments, and also the basically parts diagram with the name of the parts. Will you post your "6 page with step by step directions"? It would be very helpful for all when doing the rebuild. I have a rebuild paper for the 28 and 228 if you need a copy.
Its a generic rebuild sheet. Will you also post your "generic rebuild sheet"? It should be helpful during the rebuild too.
-Tom
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Thks I'll just forget it. I may just put an inline filter for it. My truck initially had the inlet filter, but GMC issued a TB to remove them. I may still have it... can post pics but not for sale.
I've never seen one for sale. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | If ANYONE wants the 28/228 pdf just PM me. I also have a chapter from a manual that's about 20 pages and is much more thorough (jet sizes, performance diagrams etc). I have the manual digitized and that will be posted at some point on my web site ( www.tm9-801.com in the technical publications link) this will be watermarked so restorers know where it came from and can get other publications of interest. The 28/228 pdf will not be watermarked as I have no plans to post it on my site. Once you have it you are free to post it wherever you like. I don't want the hassle of having to write a web page, alter links on my site, etc etc. I think I can send files via PM here... if I can I'll do that. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Here's s a snippet from page 1 (its actually 11 pages)
The 28AV and BV and 228-Series Carburetors are of the single barrel, downdraft type with a primary and a secondary venturi. The secondary venturi is pressed into the primary venturi. These carburetors are of the "balanced" design in that all air for fuel bowl ventilation and idling must enter through the air cleaner. For this reason any restriction in the air cleaner will have a minimum effect upon the fuel-air mixture ratio. These models include single idle, main, accelerating and power jets. The accelerating pump is operated mechanically by throttle movement through a link connected to the throttle lever. The power jet is operated by engine manifold vacuum.
The basic difference between the 28 and 228 Series is in the idle system. The 28 series has a single idle discharge plug in line with the closed throttle plate. The idle needle valve is located in the air intake body, see Figure 3. The 228 Series includes a two hole idle system with one hole located above the closed throttle plate and the other below the plate with the idle needle valve located in the throttle body, see Figure 3a, | | |
