| | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | It seems there are no venders for the 55-59 LCF GMC's Anyone know if the weatherstrip for the doors are reproduced for the LCF 1959 GMC or Chevys? I have already purchased a set for a pickup, hoping to make some of it work. I know I will have to fab something for the end where the hinges are. Thanks.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if Steele doesn't make it you're not likely to find it - won't be listed in their catalog, but would be worth making a phone call .... I assume your doors have the holes for the peg type of attachment, and the profile is the same as for the conventional cab - you can get that profile in strips [as opposed to one piece formed to fit], which should be usable
Bill | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Bill, the doors do have the holes for the pegs, except the end where the hinges are. There is still some of the old stripping there. It changes to a flat piece that sort of forks around the hinges. Also the bottom does not have the holes. I tried to salvage all the old stuff, so I could understand how it works. I am sure the pickup part will work on the handle side and across the top of the windows, down to where the big cutout is. Thanks much.
