2 members (Jay R, Donf),
71
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | My cowl vent side brackets are rusted at the pivot points which makes the vent very hard to open and close. I have sprayed with WD-40 and lubricated them with oil. Still very hard to move. Don't want to break them. What works the best to free these brackets up so I can open and close the cowl vent without issues?
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | try a mixture of dextron trans fluid and asetone mix 50/50 . brush it on and let it set for about 1 hr it works on rusted nuts and bolts | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I would break the screws and remove the vent, then put new hardware in and clean everything up in the meantime. That's what I did on my 46 and it works great now. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I have already removed the cowl vent cleaned it up and painted it, but the pivot points on the brackets attached to the cowl are very hard to rotate. The rust has gotten in between the lever and base. These brackets appear to have a rivet as a pivot. I've got them to move some, but want to free them up so the cowl vent will operate properly without damage to the brackets. I really am trying to avoid breaking the brackets. The hardware I removed were small carriage bolts with flat washers and lock washers. Can't seem to find replacement hardware the same size?
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Try an electrical supply place for the smaller screws. They get used a lot in that field.
Steve H
| | | | | Joined: May 2014 Posts: 1 Moderated | | Moderated Joined: May 2014 Posts: 1 | A product called PB Penetrating Catalyst works great on rusty parts. Much better than WD-40. Available at Home Depot in hardware lubricant section. | | |
