3 members (G508, Peggy M, Uncles51), 111 guests, and 2 robots.
Topics128,028
Posts1,055,414
Members48,422
#1027123 05/08/2014 2:00 PM
My cowl vent side brackets are rusted at the pivot points which makes the vent very hard to open and close. I have sprayed with WD-40 and lubricated them with oil. Still very hard to move. Don't want to break them. What works the best to free these brackets up so I can open and close the cowl vent without issues?
1970 VW Beetle
try a mixture of dextron trans fluid and asetone mix 50/50 . brush it on and let it set for about 1 hr
it works on rusted nuts and bolts
I would break the screws and remove the vent, then put new hardware in and clean everything up in the meantime. That's what I did on my 46 and it works great now.
My 46 GMC on Photobucket
I have already removed the cowl vent cleaned it up and painted it, but the pivot points on the brackets attached to the cowl are very hard to rotate. The rust has gotten in between the lever and base. These brackets appear to have a rivet as a pivot. I've got them to move some, but want to free them up so the cowl vent will operate properly without damage to the brackets. I really am trying to avoid breaking the brackets. The hardware I removed were small carriage bolts with flat washers and lock washers. Can't seem to find replacement hardware the same size?
1970 VW Beetle
Try an electrical supply place for the smaller screws. They get used a lot in that field.
Steve H
Moderated
Moderated
A product called PB Penetrating Catalyst works great on rusty parts. Much better than WD-40. Available at Home Depot in hardware lubricant section.
