1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 2 Moderated | | Moderated Joined: May 2014 Posts: 2 | I have a 1950 3100 that has a blown up 216 motor. I also have a 48 1 1/2 ton or 2 ton grain truck with what I belive has a 216 motor also. I was going to take the motor out of the grain truck and put it in the 3100 pickup but a mechanic told me that they had run into an issue a while back that the motors were not the same and woud not work in the 3100. Anyone know for sure if this is the case? Thanks, | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The engine should be a 235, and will work in the pickup. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The big truck motor may have a governor on it, but the motor itself will fit just fine. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The first thing is to identify that the engine in your grain truck is indeed a 216. There is a chance that it could be a 235. That shouldn't matter, they are physically the same size engine, the displacement is different. If it is mounted in your grain truck there should be no difference in mounting in your 3100 using your bell housing/flywheel/clutch etc. Use these TECH TIPS to help you identify what you have. TECH TIP #2 CASTING NUMBERS | | | | | Joined: May 2014 Posts: 2 Moderated | | Moderated Joined: May 2014 Posts: 2 | Thanks guys appreciate all the help. Now I am going to have fun with my project!!! | | |
